Generally Control Room (CR) is located in an Industrial plant at the centre of the I&C components in the field to reduce field cabling. Other considerations for CR location are safety of operating staff from hazards, like Chemical explosions, toxic gas release, floods etc.
However in Power plants CR is normally kept at higher elevations at the same level as that of Turbine operating floor. Why the CR can not be located at lower elevations so that the operating staff has easy and quick access to other areas of the plant? Whether monitoring/control at Turbine operating floor is so critical for CR operator?
Plant Layout
Started by Mantu, Jun 27 2003 07:04 AM
Posted 27 June 2003 - 07:04 AM
Posted 02 July 2003 - 09:21 AM
Hi there,
I worked in a company in which there was a separate power house for generating HP steam and electricity. The control room was situated at the same floor where the turbine was. The reason that I was told that, for ease of observation/close monitoring of the turbine. There we did not have cutting edge control systems and u can easily hear any abnormal sound/change in the sound of turbine. The movement of personnel to the turbine area was easy and less timeconsuming. As u know if the turbine trips then how much down time u would have to suffer....
hasani
hasani
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
Variables That Affect Energy Consumption Of Methanol PlantStarted by Guest_mobody_* , 15 May 2024 |
