Hi all,
I have the solubility of CO2 in Selexol given in SCF/USGal and I am trying to take out of that mole CO2/mole Selexol. My concern is about the SCF conversion. Do I have to include the temperature term (60 oF) for the SCF to have STP at least as a first result? I would appreciate if anyone could help.
Scf Conversion To Mole Fraction
Started by z_kapetaki, Aug 16 2010 10:35 AM
Posted 16 August 2010 - 10:35 AM
Posted 16 August 2010 - 11:31 AM
I'm not sure if I understood your question well, but if conversion from SCF to Sm3 is concerned it is very much straightforward since both refer to standard conditions (101.325 kPa, 15.6 degC).
For converting from SCF/gal to mol/mol you need Selexol density and Moleculer weight.
Posted 16 August 2010 - 12:28 PM
Having dealt with CO2 removal processes for a long time, I believe I know what you are faced with. You are probably trying to convert a CO2 loading given in normal USA units as SCF/USGal to CO2 moles/mole of Selexol. You need this to relate to published data. Am I correct?
If so, then you should take into consideration that for a gas there are 379.48 ft3/lb-mol at 60 °F and 14.696 psia. These are normal USA units and they have nothing to do with the term Normal as employed in Europe. I try to shy away from using the term standard. Every body and his brother has his own standard conditions and more are being fabricated every day. It is safer and more prudent to simply always refer to your base temperature and pressure (you failed to state that you are referring to atmospheric pressure therefore, I base myself on the stated 14.696 psia).
As Zauberberg states, this is only half of the job. You also need to know the density and the molecular weight of the Selexol solution that you are employing.
Posted 16 August 2010 - 01:28 PM
Every body and his brother have their own “standard” conditions – and more are being fabricated every day.
Posted 17 August 2010 - 04:48 AM
Hello Art,
This is exactly what I am trying to do!
Thank you very much for the reply. So in that case, you think it's more accurate to calculate moles in 60 oF and 1 atm and then make the conversion to any temperature. The densities, though, usually are given in NTP (25 oC and 1 atm). Thank you both for the posts.
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
![]() ![]() How To Calculate Mass Fraction Flow Rate?Started by Guest_chemtoli_* , 30 Jun 2023 |
Query Regarding The Mole Flows Of A CstrStarted by Guest_Marcaus01_* , 23 Jun 2023 |
Maximum Number Of Regeneration Cycles In Mole SieveStarted by Guest_YouAB_* , 23 Apr 2023 |
