Could someone please give me a hand and let me know if it is possible to model radiation levels from flaring using Phast software? If so, can someone give me a quick overview of what steps I need to select in the program?
I would be very grateful.
Radiation Modeling With Phast
Started by areads, Aug 20 2010 07:37 AM
Posted 20 August 2010 - 07:37 AM
Posted 30 July 2011 - 10:12 AM
Yes, you can use the Jet fire model for determining the radiation from flare.
Most of the data are like any other model in PHAST except that you need to key in the location of the receptor points as well as the flow rate from the flare, for which you may have to trial and error with pressure until you get the approximate flaring rate.
Hope it helps.
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Monolith Reactor ModelingStarted by Guest_sam.lyzzaik_* , 30 May 2024 |
![]() Modeling Of A Separator (No Liquid Outlet)Started by Guest_niketas_* , 06 Nov 2023 |
Modeling Membranes In Aspen PlusStarted by Guest_Airport_* , 30 Oct 2023 |
