Membrane Technology
Started by alokjaiswal, Aug 27 2010 12:45 PM
8 replies to this topic
Posted 27 August 2010 - 12:45 PM
Has any process engineer implemented the idea of recovering CO2 from the flue gas of any furnace, the flue gas being operated at 170 deg C?
Posted 27 August 2010 - 01:21 PM
Alok,
Please find attached an article on CO2 recovery. Section 5.2 of the attached article gives details about CO2 recovery from flue gases.
Posted 28 August 2010 - 01:13 AM
Dear Ankur,
I dint find any article attached by you. if you have any, then you can mail me also.
Posted 28 August 2010 - 01:32 AM
Alok,
I have tried to attach it but the upload is failing repeatedly. I have informed the administrator.
Posted 28 August 2010 - 01:35 AM
Is there any particular reason why do you want to employ membranes, or it is just a screening study? There is one interesting paper attached below.
Also, if you look at previous threads on the same topic, I believe there are two or three very interesting discussions about the use of membranes for acid gas removal.
If you are interested in other flue gas treatment technologies, browse for the "CanSolv" process.
Posted 28 August 2010 - 02:00 AM
Alok,
I am uploading another article on CO2 capture. Let us hope this upload works.
Posted 28 August 2010 - 05:03 AM
Basically, I am looking for feasibility of membrane wrt cost and space availability. Suppose, if there is 200 KNM3/hr flue gas flow at 170 deg C, then what will be the cost of membrane tech as compared to solvent tech.
Posted 28 August 2010 - 07:38 AM
For detailed evaluation, you will need to obtain basic design information and preliminary estimate from the membrane vendor(s). One thing which doesn't support using membrane systems in CO2 removal applications, is their low selectivity. As described in the article, you might be forced to use a recycle Permeate compressor in order to make the process more efficient. Increasing the feed gas pressure has the same effect.
Make sure to compare both processes on the same basis, i.e. for the same inlet conditions and the same product (outlet streams) specifications.
Posted 28 August 2010 - 08:54 AM
There are a number of issues. first I would ask what is the volume or mass concentration of C)2 in the flue gas?
The main issue for he information you have provided the 170C; many membrane operations will not tolerate such temperatures. Membrane solutions for this application are typically in the research phase; try science direct.com for more references.
The reason why membrane are being considered is the alternatives are not easily viable or cheap especially as CO2 concentrations get high. For CCS this is the trend.
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
Looking For Technology And Software Related WebsiteStarted by Guest_Ashish__* , 03 Sep 2024 |
Ethylene Plant TechnologyStarted by Guest_CHEMSTRONG_* , 06 Jul 2022 |
Process Technology LicenseStarted by Guest_kangas_* , 20 Jan 2022 |
Methyl Chloride Abatement TechnologyStarted by Guest_TheChemEng_* , 26 Aug 2020 |
