Compressibility Factor
#1 eastorca
eastorca
  • 69 posts
Posted 06 September 2010 - 10:01 PM
Hi everybody
I'm calculating the Comperssibility factor of gas. Which book, diagram or equation i coul refer?
Thank you
  • 6,940 posts
Posted 07 September 2010 - 12:20 AM
Please use the search button ( right hand side) .
If you need more info , I will advise you to use google , plenty of reference there .
#3 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 07 September 2010 - 08:47 AM
Dear,
Pick any book on chemical engineering thermodynamics and start calculating the "Z" with different Equations of State.
#4 eastorca
eastorca
  • 69 posts
Posted 07 September 2010 - 10:15 AM
Thank for kindly remind me. The problem was clear now.
#5 mbeychok
mbeychok
  • 364 posts
Posted 07 September 2010 - 12:31 PM
eastorca:
I highly recommend that you read this article in the online Citizendium encyclopedia:
Compressibility factor (gases)
Milton Beychok
#6 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 10 September 2010 - 12:31 AM
I'm calculating the Comperssibility factor of gas. Which book, diagram or equation i could refer?
In addition to the useful posts already sent, you can find compressibility factors of several gases in Perry's Chemical Engineers' handbook, Physical and Chemical data, Compressibilities (p. 2-140 to 2-150 in 7th edition). If the specific gas is not there, you can use the corresponding states theory to find z (compressibility factor) from reduced pressure and temperature (which is logically less accurate). Hougen, Watson, Ragatz had published the latter generalized method in their books (Chemical Process Principles, ca 1947-1957), which can be found in many books now (as pointed out already in posts).
