hi everyone
i am working in a plant that produces chlorinated parrafins and we have hydrocloric acid as a byproduct and we are looking for adding new unit for producing calcium chloride by reacting hcl with limestone ifanyone can please help me with flowsheets for this process i will be greatfull
thank you
waiting for your help
Calcium Chloride Production Flowsheet
Started by alostora_oo7, Oct 03 2010 11:25 AM
Posted 03 October 2010 - 11:25 AM
Posted 03 October 2010 - 12:51 PM
alostora_oo7:
You failed to fill in your personal information, so I am unable to determine where you are located at and, therefore, cannot refer you to any sources within your environment.
Calcium Chloride is an elementary inorganic product that is derived from a variety of processes - both as a by-product (Solvay) or direct. Since this is not the Student Forum, I would expect that you are a professional engineer and that you have done the usual, to-be-expected research and background check on what you are looking for. I would expect you have poured over the Internet - as I did - and found the following information from a long list of references:
http://www.freepaten...om/4299809.html
http://www.southinve...um Chloride.pdf
where you will find the following reference to a production facility that could furnish you with the information that you are looking for:
Ravi Kiran Industries
Tel. +91-22-28506569
Fax. +91-22-28506135
Posted 04 October 2010 - 11:25 AM
alostora_007
In addition to the valuable information provided by Art Montemayor, have a look at the following link:
http://www.tetrachem...asp?page_ID=527
There are two downloadable flow sheets in the above mentioned link.
Posted 04 October 2010 - 07:12 PM
Mr 'Art Montemayor'
thank you for your reply and your help and you mentioned that i didn't fill my details in my profile
i am from egypt and i would be thankfull if you would supply me with information about how to start studying a new unit because in egypt we have a problem in the workfield that chemical engineer works only with operation and control we have no design no R&D no creative thoughts we almost work as operators here so building a new unit is kinda weired here and i found no help even from experienced process engineers
so if you can help please me or at least guide me to my start point this will be great
and thank you again
and thank you again
Iron Sulphate Heptahydrate ProductionStarted by Guest_baam353_* , 19 Jul 2025 |
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
