Hi all
I need help in sizing of a knockout drum.
I tried sizing a vertical knockout drum with demister pad using 2 methods - settling velocity and k factor (GPSA databook) - but got completely different results. The conditions are as follows:
gas density: 3.3 kg/m3
liq density: 1000 kg/m3
gas volumetric flowrate: 10 m3/s
viscosity: 0.012 cp
diameter of particle: 100 microns
Also, could you let me know how do we go about calculating the length once the diameter has been calculated?
Any help is appreciated
Sizing Of Knockout Drum
Started by racerX, Oct 17 2010 11:44 AM
Posted 17 October 2010 - 11:44 AM
Posted 17 October 2010 - 12:41 PM
RacerX,
Where you find difference during your calculation, use EXXON standard for drum sizing, it will give you simple directions for calculations.calculate critical velocity and calculate area by dividing flow over critical velocity. Moreover, you are calculating the vessel size or mechanically designing the vessel, if mechanically designing then you need lot of calculations but if process side then you need to calculate vessel area and PS,s etc. mechanical design include inlet nozzle, outlet nozzle, manway, vessel thickness, inlet/outlet piping also.
One thing you miss in your parameters, what is liquid flow, you mention total, for calculation of area you need gas as well as liquid flow also.
Toor
Toor
Posted 17 October 2010 - 07:51 PM
let you try the search button , right hand side, you will find a lot of information.
Posted 17 October 2010 - 11:57 PM
An other resource which should support your query.
Hope this helps
Hope this helps
Posted 19 October 2010 - 01:16 AM
Hope this helps
Hi Breizh,
I downloaded the attached document,Section 9:Flare Knock-out Drums refers me to IPS-E-PR-460 for detail sizing procedures. I would appreciate if you can send me the document if it is within your strength to ashjanj18@yahoo.com because i need deatil information on how i can have a reasonable design for the flare KO drum required at the Booster station we are designing.
Thanks for your anticipated cooperation.
Asade
Posted 19 October 2010 - 02:30 AM
Hope it helps
Hope it helps
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
