Hot Oil Flushing
#1 ajayd
ajayd
  • 27 posts
Posted 22 October 2010 - 02:52 AM
Hi Everyone,
This is reference to one of our enquiry in which we have to provide Hot Oil System. As in to these i am not well aware of the flushing of the system using mineral oil.
Please let me know,
1) Is it mandatory to use mineral oil or can we use operating oil Hytherm 500?
2) Which type of mineral oil we use for flushing?
3) Its really appreciable if you send me the data sheet for the mineral oil.
Thanks,
  • 6,733 posts
Posted 22 October 2010 - 03:32 AM
Yes it is mandatory to have a system clean prior to introduce hot oil otherwise you will experience degradation of the oil and then start the problem . I will advise you to discuss with your vendor .
I've attached a document from solutia .
In any case don't introduce moisture in your system .
hope this helps
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 22 October 2010 - 10:46 AM
ajayd,
Your question is incomplete without the details of what you want to heat using hot oil. There are several types of Hot Oils or Heat Transfer Mediums available for a wide range of heating applications. Some of the most commonly used synthetic heat transfer mediums are Diphenyl:Diphenyl Oxide (DP:DPO) eutectic mixture, chlorinated biphenyls, molten salts and silicon based heating oils. Unless you tell what is the heating application, it would be difficult to recommend the type of heating oil.
#4 breizh
  • 6,733 posts
Posted 24 October 2010 - 07:37 AM
Ajayd ,
An other paper to support your query , when filtration cannot remove the dirt:
http://www.purewater...herminol_ff.pdf
Hope this helps
