what are different unit operations used in chemical Industry
actually i want detail information about unit operation
unit operation types uses etc..
Unit Operations
Started by Suraj Pathak, Oct 24 2010 05:22 AM
Posted 24 October 2010 - 05:22 AM
Posted 24 October 2010 - 12:49 PM
Suraj:
The manner in which I have always dealt with Unit Operations (and its counterpart, Unit Processes) is the following:
A Unit Operation is a process that results in a Physical Change - it depends on the same basic laws of physical science that applies to all other branches of engineering. Some examples are: separation of components (distillation, filtration, flotation, absorption, adsorption, etc.), heat transfer, transport of fluids, gas compression, evaporation, phase changes, etc., etc.
A Unit Process is a process that results in a Chemical Change - such as a chemical reaction or decomposition. This division of Chemical Engineering is more narrow and specific - however, it tends to be more complex and difficult. A nuclear reaction is a Unit Process; the subsequent utilization of its released energy into useful electricity is a series of Unit Operations.
If you desire a listing of all the possible Unit Operations out in industry, I recommend that you, as a student of Chemical Engineering, do a serious research using your text books and the Internet and develop one. This is an excellent preparatory tool for young students.
Posted 07 November 2010 - 07:38 AM
The attached document will surely help you.
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
