Steam Turbine And Gas Turbine Simulation
Posted 03 November 2010 - 04:59 PM
Does any one know how to simulate a steam turbine, boiler and a gas turbine (combined cycle, including the gas turbine and a Heat Recovery Steam Generator) in either Hysys or Pro II? Both boiler and gas turbine firing fuel gas.
I would like to simulate a steam system that maximizes the use of fuel gas to produce steam and power, that's why I am looking for how to simulate the boiler and turbine system that I can specify the fuel gas firing.
Which unit operations should I simulate the boiler, steam turbine and gas turbine? In other words, what are the subsystems of the boiler, steam and combined cycle turbine?
Posted 05 November 2010 - 10:03 AM
I am not familiar with Hysys or Pro II. But this webinar may be of help to you:
"Modeling & Simulating Gas Turbine Systems"
http://www.flowmaste..._demo_form.html
They have 4-5 other webinars on gas turbines, as well as one coming up next week on cooling loops:
"Simulating Cooling Systems for Efficient Design"
This educational session will discuss the use of system-level simulation on liquid cooling systems to address key design considerations and common challenges in power generation, plant and process industries.
https://flowmaster.w...92&RT=MiM3&FM=1
Hope this helps! Best of luck!
Posted 06 November 2010 - 01:14 PM
Posted 18 November 2010 - 09:18 AM
Few years back I tried to model the Gas Turbine with HRSG. Give me your mail id so that I can send you the file.
Posted 21 November 2010 - 10:19 AM
thanks alot. My email ID was sent to you.
Hope to receive your file.
Have a nice weekend
Edited by Art Montemayor, 06 April 2011 - 05:05 PM.
Posted 14 January 2011 - 10:58 AM
By the time you posted this comment I was in hospital and could not reply you but here is your file. Only thing you need to access this file is to change its extension to .rar from .pdf and extract with winrar extractor (same as .zip). This is the simulation which I did 3 years back. All the necessary back up calculations are done in the spreadsheet. Hope it helps you.
Posted 19 January 2011 - 05:28 PM
Posted 26 January 2011 - 12:30 PM
Dear,
srihari5043@gmail.com
Posted 23 February 2011 - 09:43 AM
Vishnu
vishnu1988@hotmail.com
#10
Posted 04 April 2011 - 11:00 PM
Can you please check and upload the attached file again, because it seems could not be opened properly. I thought because my Hysys license expired so I could not open it but another guy, Vishnu, has the same problem opening the file.
Warm regards,
Kat
Edited by Art Montemayor, 06 April 2011 - 05:07 PM.
#11
Posted 06 April 2011 - 03:18 PM
#12
Posted 23 November 2011 - 12:51 PM
Thank you in advance
Htait
htait_ali@hotmail.com
#13
Posted 24 November 2011 - 01:55 AM
Dear Sir,Dear Kat,
Though I changed the extention to *.rar, unable to extract and am getting some error. Do not know why. Attaching for your help please!!
samrat
#14
Posted 15 February 2012 - 06:48 AM
please could you send me this the gas turbine and HRSG you modelled.
marouenbenakermi@ymail.com
thank you
#15
Posted 23 February 2012 - 04:47 AM
I am able to convert pdf to *.hsc. Thanks once again.
samrat
#16
Posted 01 March 2012 - 02:27 AM
Herouini@gmail.com
#17
Posted 29 October 2012 - 08:53 AM
jpcavallaro@gmail.com
Thank you.
#18
Posted 12 December 2012 - 02:36 AM
The file is same and is already uploaded in my earlier post. Please download it and follow the instruction given in earlier post. The file still works.
#19
Posted 03 March 2013 - 05:54 PM
#20
Posted 13 July 2013 - 08:47 AM
Dear kat and all of guys nice to meet you on this group.
I would like also to simulation power plants by using hysis..
Can you give me guide to do it??
#21
Posted 13 July 2013 - 09:33 AM
Dear padmakar,.
can you helps me to share your gas turbine and HRSG modelled, i also want to find the idea in your simulation.
Warm regrds,
Stevanus
#22
Posted 26 July 2013 - 02:35 PM
Hi all,
I need help in performing dynamic simulation of steam network of a refinery with its Captive power plant in HySys like how to incorporate GTs-HRSGs & Aux-boilers in HySys, etc.
Mr Padmakar, can you please help in downloading the attached pdf of your work as i am still unable to download the same, in the meanwhile would request to please mail me the excel sheet of backup calculations.
Thanks.
