Gas Pressure In Burner Tip
Posted 12 November 2010 - 02:06 AM
Is possible anybody tell me about gas pressure in burner tips.
Best regards
Posted 12 November 2010 - 03:30 AM
Posted 12 November 2010 - 10:05 AM
Posted 13 November 2010 - 12:01 AM
Thanks for your nice response.
I want to know the gas pressure in burner and pilot exact before lighting up?
thank you
Posted 13 November 2010 - 05:16 AM
This information should be readily available in the Plant Operating Manual, and within the Burner Datasheet as well.
Thess values vary from plant to plant, and if you are asking for any particular system - such data have to be provided within supplied equipment information. There is no such thing as "universal pilot gas pressure", or "lightning burner tip pressure".
Posted 14 November 2010 - 12:31 AM
I BELEIVE THERE IS NO UNIVERSAL STANDARD FOR THIS PARAMETER .
BUT THERE IS A NORM THAT ACCEPTED AS NORM BY BOILER OR BURNER MANUFACTURER.
WE ARE LOOKING FOR SUCH NORM
FOR YOUR MORE INFORMATION OUR BOILER SPECIFICATION IS AS FOLLOW:
1-NORMAL STEAM DRUM PRESSURE:11.6 BARG (SATURATED)
2-MAX RATE:55 TON/HR
3-NORMAL RATE :45 TON/HR
4-FUEL GAS COMPOSITION : A-METHANE 82% AND B- ETHANE 14%
BEST FOR YOU
Posted 14 November 2010 - 08:30 AM
The pilot gas, where practicable, shall be taken from a sweet gas supply, independent of the main burner gas, or from a separate off-take on the fuel gas main, with its own block valve and spade-off position. Unless otherwise approved by Company, the pilot gas pressure shall be controlled at 35 kPa (0.35 bar) and the pressure regulating valve shall be the self-operating type.
For fuel gas systems and boilers, read more at:
http://igs.nigc.ir/ips/pr/e-pr-340.pdf
http://igs.nigc.ir/ips/pr/e-pr-800.pdf
Good luck,
Kitchen Stove Burner TypeStarted by Guest_Vegeta_* , 27 Jun 2025 |
