Raymond Mill confidential by the host, analysis machine, blower, finished cyclone, plumbing fixtures, electrical and other components. Which the host from the rack, into the wind scroll, blade, roller, grinding ring, cover and motor. Auxiliary equipment are jaw crusher, bucket elevator, electromagnetic vibrating feeder, cabinet, etc., the user can flexibly choose according to the site.
High Pressure Grinding Mill hosts, the hanger fastening a roller pressure of 1000-1500 kg of high-pressure spring. Begin work, around the spindle rotation roller, high pressure spring and centrifugal force in the dual role, close to the grinding ring rotation, the rotational power than the same pressure Raymond mill under the conditions of 1.2 times, so much higher yield . When grinding the material into the grinding chamber, by the shovel blade into the ground between the roller and ring rolling mill, roller compacted powder after the child with the circulating air blower into the analysis machine, qualified with the airflow into the cyclone powder powder collector collection is finished, large particles fall back to re-grinding grain. Circulating air blower to repeat the above process to return, I will enter the bag filter air purification. When the grinding roller and grinding mill up to a certain wear and tear, adjust the length of the spring pressure to maintain between roller and grinding ring constant grinding pressure. To ensure stable output and fineness.
Jaw crusher in mining, building materials, mainly for infrastructure and other departments in the broken machines and crushing machines. Width according to the size of the feed port is divided into large, medium and small three, than the width of feed opening 600MM for large machines, the width of feed opening for the 300-600MM medium-sized machine, feed a mouth width of less than 300MM the minicomputer.
Jaw Crusher is partly the work of two jaw plates, one fixed jaw plate (fixed jaw), vertical (or the top of the slightly extrovert) fixed to the body before the wall, and the other is the active jaw plate (moving jaw), location tilt, with the fixed jaw plate under the formation of small, big crushing chamber (the working chamber.) Activities against the fixed jaw jaw board to do the periodic reciprocating motion, sometimes separately, sometimes close. Separately, the material into the crushing chamber, finished unloading from the bottom; close, so that jaw plate mounted between the two materials are extruded, the role of bending and splitting broken.
Jaw Crusher jaw plate of the swing by activity in different ways, can be divided into simple swing jaw crusher (jaw crusher simple pendulum). Complex swing jaw crusher (Jaw Breakers) and integrated swing jaw crusher three.
The structure of the stone crusher main frame, the eccentric shaft, a large belt pulley, flywheel, moving jaw, side guard, elbow board, elbow board seat, adjusting screw gap, the reset spring, the fixed jaw jaw and other components and activities, bracket which also play a role in the insurance. This series of jaw crusher way for music moving extrusion type, motor-driven belt and pulley, the eccentric shaft to move through the upper and lower jaw movement, when the moving jaw toggle plate and moving up when the angle between E major, thus promoting the moving jaw close to the fixed jaw plate, while the material is squeezed, rubbing, grinding, such as multiple broken; when the moving jaw down, the toggle plate and moving jaw angle between, moving jaw plate in the bar, leaving under the action of the spring fixed jaw plate, this time the material has been broken under the discharge port from the crushing chamber, with the mobile jaw crusher motor for continuous rotation of the crushing and discharging cycle, to achieve mass production.
Stone Crusher And Grinding Mill Design Development And Status
Started by sbmboy, Nov 18 2010 03:07 AM
No replies to this topic
Posted 18 November 2010 - 03:07 AM
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
