Air-Cooler Design
#1 asade abiodun
asade abiodun
  • 146 posts
Posted 01 December 2010 - 04:51 AM
Good day All,
Please, i need information on how to design an air cooler (its power requirement and fans brake horsepower) to handle natural gas from a compressor to cool it down.
The process information is stated below:
Gas flow rate: 1738 mmscfd
Expected inlet temperature to cooler: 60 deg.C
Compressor Discharge presuure: 1250 psig
Expected outlet temperature from Air-cooler: 45 deg.C
Allowable pressure drop across cooler: 10 psi
Average ambient temperature:30 deg.C
Heat Capacity: 2.601 kJ/kg.degC
Thanks for your anticipated cooperation.
:rolleyes:
  • 6,807 posts
Posted 01 December 2010 - 06:16 AM
Hi asade,
Let you consider this calculator, at least you can get indications and references :
http://www.gearainey...Calculator.html
Hope this helps
#3 sheiko
sheiko
  • 732 posts
Posted 07 December 2010 - 01:56 PM
The attached article will surely help you.
#4 mvp
mvp
  • 16 posts
Posted 10 December 2010 - 04:20 PM
You are on the border-line for Air coolers
With Inlet @ 60C and expecting 45 C on the process side, with an Air cooler, is simply not good economics.
If you still want to use an air cooler:
1. If you want an approximate answer, try Hudson Products, ACHE software; free to download
2. Else use a good sizing tool like HTRI or ASPEN EDR
MVP
#5 asade abiodun
asade abiodun
  • 146 posts
Posted 13 December 2010 - 05:02 AM
Breizh and Sheiko, thanks for the information.
i contacted Hudson for their technical input and they responded well.
By the way, i think hedi01 should understand that this forum is to discuss technical matters not movies.
Administrator, please take note.
