I have to mix 2 gases, Hydrogen and Nitrogen to achieve a constant flow of mixed gas with 100, 200... 1000 ppm of H2 in the mixture.
I have mass flow meters to adjust the flow of each individual gas but how do I determine what they should read to achieve each of the desired ppm combinations
Gas Mixture Using Mass Flow Controller
Started by aliveinmoscow, Dec 01 2010 06:26 PM
Posted 01 December 2010 - 06:26 PM
Posted 01 December 2010 - 07:45 PM
Let you do a mass balance or mass flow balance :
* Assuming you are talking PPM mass ( part per million mass) then as an example :
a) let say 1oo ppm : 1e-4 = Mass flow H2/ (Mass flow N2 +Mass flow H2)
the second equation is the mass flow of N2 you will fix .
then you can calculate the flow rate of H2
Hope this helps
Hope this helps
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
