HI everyone,
We have a cryogenic reciprocating Liquid nitrogen pump that is used for transferring liquid nitrogen from low pressure to a high pressure tank. My boss is telling me to show a vapor return line from the pump to tank.
Can any one tell me why is this vapor return line required & how to size that line?
Vapour Return Line
Started by A mukherjee, Dec 07 2010 09:07 PM
Posted 07 December 2010 - 09:07 PM
Posted 08 December 2010 - 11:37 AM
I think you mean "vapor return line including a PV or an orifice from the high pressure tank to a low pressure tank!" It is probably in order to keep constant delta P between two tanks during transfer operation. Am I right?
Posted 08 December 2010 - 02:07 PM
I think he's referring to the pump casing vent but without P&ID or at least a sketch, it's not possible to give more detailed comment.
Pumps in cryogenic service need to be defrosted (dried), and cooled down prior to startup. The vent is used to release vapor flow from pump casing.
Posted 09 December 2010 - 10:23 AM
Hi
I had done these steps while designing a liquefied gas transfer from LP tank to HP tank.
1) In addition to a liquid line there was a vapor line connection between the two tanks with appropriate CV and PRV.
2) The liquid volume flow rate was estimated for different liquid levels in HP (High Pressure ) and LP (Low Pressure) tanks based on system curve and the pump curve.
3) The equal volume flow rate was estimated to ensure that the pressure in the HP tank remained in the operational range that was required by the plant people
4) Based on the flow rates the expected pressure drop the pipe diameter was calculated.
5) The final design conditions were simulated to view conditions at min/max operational levels.
Kind regards
Raj
Kind regards
Raj
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
