How To Fix The Elevation Of A Vessel/column Which Is Feeding Toa Pump.
Posted 08 January 2011 - 12:35 AM
I would like to understand the method of fixing the vessel or column elevation during basic design stage where NPSHr for the pump (which takes suction from this vessel / column bottom) is not available.
This is a general query which applies to process units.
Murthy
Posted 08 January 2011 - 02:38 AM
Dears,
Murthy
Using relevant previous experiences (if there is) along with considering engineering practices,we can announce vendor about NPSHA and ask him the pump with NPSHR not higher than NPSHA+Margin.
Posted 08 January 2011 - 06:36 AM
By drawing a sketch and writing down the NPSHa formula you should be able to identify and estimate the height you're looking for, knowing that you want a positive value for NPSHA.
You can consult your piping and installation department (see plot plan and other relevant drawings) or/and make some reasonably conservative assumptions.
You will then have to check these assumptions later in the project as the plant design progresses.
Edited by sheiko, 08 January 2011 - 12:02 PM.
Posted 08 January 2011 - 07:01 AM
For vessels - particularly reflux drums, they may be (and usually are) located on platforms a few meters above grade, depending on the overall plant layout/configuration.
Probably the best thing - as suggested above - is to look for similar installations and projects, and see which concept has been applied there. Unless you are dealing with quite specific process plant, there shouldn't be many unknowns and we are usually not required to re-invent hot water.
Some tips can be found here, page 39 onwards: http://igs.nigc.ir/ips/pr/e-pr-190.pdf
Posted 08 January 2011 - 09:36 AM
During basic design or in conceptual stage while performing the pump calculations, please have the pump models' data handy. This will help you to fixation of the vessel elevation. During detail engineering the elevation data given for vessel is well verified with the vendors and changes are made accordingly. In the previous designs I did, I have never taken the credit of the maximum liquid level inside vessel, rather Low Liquid Level.
Posted 08 January 2011 - 10:00 AM
Absolutely. I have corrected my previous post.In the previous designs I did, I have never taken the credit of the maximum liquid level inside vessel, rather Low Liquid Level.
Edited by sheiko, 08 January 2011 - 11:59 AM.
Posted 08 January 2011 - 11:28 AM
Absolutely.
NPSHr may be calucated as cavitation coefficient of thoma
multply pump differenal head.
