Posted 08 May 2005 - 07:50 PM
For estimating the flash point, you can use following rule of thumb:
The flash point occurs at about the temperature at which the liquid has a vapor pressure equal to the LFL partial pressure.
For example, ethanol has a LFL of 3.3 volume%. The LFL partial pressure is therefore 0.033 atm. The temperature that produces a vapor pressure of 0.033 atm is 11°C, which is the predicted flash point. This is close to the reported flash point of 13°C (see for example NFPA 325).
You can use Antoine equation to find temperature that produces LFL partial pressure.
The above is based on Gooding, Charles H., "Estimating Flash Point and Lower Explosive Limit," Chemical Engineering, December 12, 1983.
Same principle can be used to estimate flash point for mixtures. Then you also have to estimate the LFL of the mixture (e.g. using LeChatelier's Law).
