For some reason Sweeping gas flow ( which is sales gas ) to hydrocarbon flare is closed , which was flowing ( and should be) continously. I know it will cause corrosion , oxygen can ingress and lot of other problems.I want to know is there any CODES and STANDARDS regarding that I must keep sweeeping flow all the time.
Thanks in advance.
Sweeping Flow In A Hydrocarbon Flare.
Started by aanita, Jan 13 2011 09:36 AM
No replies to this topic
Posted 13 January 2011 - 09:36 AM
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
