Plume Dispersion Analysis
Started by linda_pro, Jan 20 2011 02:06 AM
Posted 20 January 2011 - 02:06 AM
Hi there,
I am doing Gas dispersion analysis for Vent Raiser on FPSO.
Unlucky, it doesn't have any simulation software in my company.
Then I think I have to do it by manual.
However, I don't know how to do that and which documents I should use...
if anyone has done this before, please advise me.
Thank you very much.
Linda
Linda
Posted 20 January 2011 - 02:34 AM
Posted 20 January 2011 - 11:21 AM
Linda,
A spreadsheet for plume dispersion modeling is available at:
http://www.rccostello.com/Airmod1.xls
It is based on the gaussian plume model and is a very simple excel sheet with certain inputs to be provided.
Alternatively you can go to the U.S. EPA (Environmental Protection Agency) web link and download their very extensive air dispersion modeling program "AERMOD" to perform your plume dispersion calculations. I have not used this but this is also based on the gaussian model for plume dispersion and is considered to be very reliable. Below is the link:
http://www.epa.gov/s...frec.htm#aermod
Hope this helps.
Hope this helps.
Posted 20 January 2011 - 08:10 PM
Thanks all for your advices.
Linda
Linda
Posted 21 January 2011 - 04:14 PM
I would use Aloha (freely available by EPA) as a first software, merely for its simplicity. Most relevant software packages require a lot of meteorological data to give some results, so you may feel confused. The disadvantage of Aloha is that it considers zero exit velocity for stack gases. Others say its results are too conservative concerning SO2. But we have applied Aloha in a seveso II (safety) study in 2006 and we saw it has a clear documentation .I am doing Gas dispersion analysis for Vent Raiser on FPSO.
After getting some familiarization with Aloha before proceeding to another software.
Another option is to make the software by yourself, which needs 15-30 calendar days for writung, debugging, testing, etc.
Instead of Aloha, you can adopt any simple known software.
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
![]() ![]() Two Phase Analysis For Liquid Oxgen TankStarted by Guest_alaasleem2026_* , 22 Aug 2024 |
Analysis Of Ammonia Content In EthyleneStarted by Guest_Movers_* , 04 Jun 2024 |
Pressure Relief Atm Dispersion Of Flammable/toxic Gases - Mist FormatiStarted by Guest_Xenolithian_* , 22 Nov 2023 |
![]() Aspen Plus - Sensitivity Analysis / Case Study - Need AssistanceStarted by Guest_SickPuppy0_* , 07 Feb 2023 |
