Nace Plates For Equipment In H2S Environment
Posted 04 February 2011 - 09:31 AM
i'm currently working for a hydrocyclone package consisting in some equipments like oil skimmer, hydrocyclone and nutshell filters for the treatment of oily water coming from desalters, separators etc..
The oily water cointains
- 200000 ppm of salt
- 1780 ppm2 H2S
- the system is workin at the following pressure from upstream to downstream:
oil skimmer: atmospheric
hydrocyclone: 8 barg
Nutshell filters: 5 barg
Treated water out: 3 barg
- Temperature: max 60°C
All vessels are in carbon steel with internal lining of 375 micron in order to protect from salt.
Our client asked us to construct the vessels with NACE plates due to the presence of H2S.
I would like to know if this is necessary or not, considering that the CS is protected with the internal lining. I've purchased NACE M0175 but im' studying it..I think that the use of NACE plates,if not necessary, would increase fabrication price..
regards and thanks
MAtteo
Posted 28 February 2011 - 04:23 PM
You have not advise pH of water, assumed below 6 for this case.i'm currently working for a hydrocyclone package consisting in some equipments like oil skimmer, hydrocyclone and nutshell filters for the treatment of oily water coming from desalters, separators etc..
The oily water cointains - 200000 ppm of salt - 1780 ppm2 H2S
- the system is working at the following pressure from upstream to downstream:
oil skimmer: atmospheric hydrocyclone: 8 barg Nutshell filters: 5 barg Treated water out: 3 barg
Since weldings should be annealed, NACE would result in serious increase in fabrication cost (it is said to be doubled for piping).
It is not easy to foretell whether internal lining would effectively resist abrasion in hydrocyclones. Some of these linings show excellent durability, yet this is a matter of experience and experimentation. Sometimes lining is destroyed locally and water goes beneath it.
Everything depends on experience gained from previous cases. I would not apply NACE standards in fabrication only in case I were certain about the durability of lining.
Equipment Spec SheetsStarted by Guest_Ken Bicknell_* , 07 Jun 2023 |
Heat Losses Of EquipmentStarted by Guest_panoska_* , 20 Oct 2022 |
Deaerator Equipment In BoilersStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
How Do We Model Leaks In Various Process Equipment?Started by Guest_lnbsak_* , 13 May 2022 |
Cost Estimate For Process EquipmentStarted by Guest_kangas_* , 22 Dec 2020 |
