Article From Hydrocarbon Processing
#1 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 19 February 2011 - 02:20 AM
I have been trying to search a paper from "Hydrocarbon Processing" titled:
"What Process Engineers Need to Know about Compressors" by W. Dimoplon
Hydrocarbon Processing, Vol. 57, 5, 221, May 1978
The article is more than 30 years old and hence I am not getting the right sources to search for this article.
Any help would be appreciated.
#2 chemsac2
chemsac2
  • 119 posts
Posted 20 February 2011 - 12:28 AM
Ankur,
Article that you need is attached.
I tried to send it to your e-mail address, but it was not delivered.
Sachin
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 20 February 2011 - 01:09 AM
Sachin,
Thank you very much for the article. I have been continuously researching the subject of compressors and this article would definitely help.
I have been trying to establish a regressed correlation between the polytropic efficiency and the inlet volume flow as given in the Figure 2 of the article provided by you.
The regressed correlation is based on some data obtained from other sources and then plotting a graph in excel for the inlet volume flow versus polytropic efficiency, genarating a trendline and subsequently generating a logarithmic equation for the polytropic efficiency.
I should be able to post the equation in a day or two after some further verificaion is done.
#4 processengineerx
processengineerx
  • 24 posts
Posted 13 June 2011 - 05:13 AM
Dear Sir,
Have you developed the relation between polytropic efficiency and the inlet volumetric flow. Would you like to share it?
#5 breizh
  • 6,769 posts
Posted 13 June 2011 - 06:10 AM
you will find the correlation delopped by ankur , I've added a second one in this post (sheet 1 & 3)
http://www.cheresour...dpost&pid=48983
Edited by breizh, 13 June 2011 - 06:12 AM.
#6 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 15 June 2011 - 12:53 AM
processengineerx,
Please look at the following blog entry:
http://www.cheresour...et-volume-flow/
The equation given can be used to calculate the polytropic efficiency given the inlet volume flow rate.
