I have tried to countercheck the flow meter in the line through the use of sight glass.
Please refer to the attached file for the procedures conducted and observations during the test.
My problem is:
The flow drops down whenever i switch line from main supply to "sight glass" line and level in the sight glass does not go down. I am suspecting that no nitrogen was flowing or the bubble i had observed could have created a space at the upstream line of the sight glass (b/n nitrogen supply line and sight glass) and prevents the flow.
But the sighglass is located at considerable altitude as compared to the pump (~1m).
Previous tests have been successfully conducted before (~ 2-3 years ago).
Thanks for your insights.
Edited by cat, 22 February 2011 - 01:18 AM.
