hai every body,
i have 2 questions...
1.Iam working on hysys for natural gas hydrates so in that simulation,i was struck at reactor duty ..so how to find duty of chemical reactor.
2.can we handle solids with reactors?and will hysys is compatible with solids..
thank you
Duty Of Chemical Reactor
Started by UNIVERSAL, Feb 25 2011 11:12 AM
Posted 25 February 2011 - 11:12 AM
Posted 25 February 2011 - 11:30 AM
What do you mean by " I was stuck at reactor duty"??
Did you intend to write that you progressed through the simulation untill the reactor, and now, having added the reactor module to your simulation, you are facing trouble in specifying the reactor ? What is the reaction? Is it endothermic or exothermic?
Have you gone through HYSYS documentation?
Edited by pavanayi, 25 February 2011 - 11:31 AM.
Posted 25 February 2011 - 11:41 AM
Hai ,
yes i ran my simulation up to reactor
my reaction is 1mole of methane+6moles of water-->1mole of natural gas hydrate
i dont know the duty of reactor so how to proceed further....iam using hysys software
thank you
thank you
Posted 25 February 2011 - 03:26 PM
1. Add the inlet streams, an energy stream and outlet streams to the reactor
2. Add the reactions to the reactor
3. Specify the temperature of the outlet stream.
Your simulation should run now if you have done the above correctly.
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
![]() Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
Secondary Heating Loop For ReactorStarted by Guest_TheChemEng_* , 28 Nov 2024 |
