Flare Height Calculation
Started by HKk, Mar 04 2011 10:07 AM
Posted 04 March 2011 - 10:07 AM
Dear Friends
I would like to know the governing case for flare height calculation in NG based Ammonia Plant. What could be the point from where flow is to be considered for this. If flow from different points ( eg LTS o/l Absorber i/l , o/l NG line) are to be considered concurrently or only one point of flaring is to be considered for calculation.
regards
regards
Posted 06 March 2011 - 06:16 AM
I can only say that once (1990) we specified flare header size based on hydrocarbon gas discharge, given by the foreign company elaborating basic engineering (mainly for cost estimation) for an ethylene revamp/propylene plant in a Refinery. There were quite a lot of discharges to flare, not all of them occurring simultaneously. As informed, there were some 12 discreet cases and 8 or 9 of them were accepted to occur simultaneously, giving the max load to flare. The whole treatment was by computer in USA and understood to be rather complex, but we had no participation in it.I would like to know the governing case for flare height calculation in NG based Ammonia Plant. What could be the point from where flow is to be considered for this. If flow from different points ( eg LTS o/l Absorber i/l , o/l NG line) are to be considered concurrently or only one point of flaring is to be considered for calculation.
For a fertilizer plant producing NH3 from NG, case may be simpler. It may be easier to estimate discharges to flare in case of fire, power failure, cooling water failure, etc, starting from each individual PSV (or other discharge to flare). Not only good knowledge of the plant, but also of the local regulations and practices is necessary, as I had understood at that time. Usually not all is clear (at least in the case of Refinery), so sound assumptions are necessary to proceed.
One final note: In another refinery a very conservative flare design was realized some 25 years ago. It has now been recognized as useful, since it covered so many new units or revamps. Not being expert, I feel that "max load" to flare (for what frequency? and how this related to discharges?)can be subjective and should be clearly documented.
Hopefully someone expert can contribute to the subject.
Edited by kkala, 06 March 2011 - 06:27 AM.
Posted 07 March 2011 - 01:27 AM
Hi HHk
for generic and standard calculation of flare stack you can follow the calculation which is given in API STD 521
Verificación De Subcolector De Venteos En Aspen Flare Analyzer V14Started by Guest_Sil_Ben_* , 26 Jun 2026 |
Convert No. Of Trays Into Packing HeightStarted by Guest_T_bag_* , 20 May 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
