I have an assignment to evaluate the heat recovery potentials in a crude oil distillation unit (picture attached). My tasks are to use the pinch analysis technique to identify the ideal maximum furnace inlet temperature, without taking into account costs, and calculate Qrec. Second task is to design a HEN to reach or get close to the ideal furnace inlet temp. Only duty and area must be specified.
Data: Extra heat provided by furnace, duty to be calculated
Extra cooling by cooling water, duty to be determined
DT = 20 C
Process stream Data (attached)
The basic design indicates that the crude oil enters the furnace at a Temperature of 290 C, but with a good design it is supposed to go over 300 C.
I use the above data in my simulation software and it calculates the composite curves (attached). I find the pinch, the recovery potential, the heat duty of the furnace and the cooling water. Now, I use the graph to identify the inlet and outlet Temperatures of the utilities. I get Tin = 295 C and Tout = 355 C for the furnace and Tin = 45 C and Tout = 95 C for the cooling water.
Am i missing something so far?
The problem is that I get an inlet temperature of 295 C and I know from literature that this can be way beyond 300 C. Do i have to complete another step to identify the inlet Temp in the furnace, or is it 295 C the max I can get?
As far as the second task is concerned, I guess after calculating the data of the utilities I have to put them in the stream table and proceed with the HEN design. I will post any questions that may arise during this step here, but meanwhile could somebody assist me in the first task?
Thanks in advance.
Edited by alfirin, 08 April 2011 - 08:35 AM.
