Hi all,
I was hoping that someone could enlighten me about valve selection (Ball vs. Gate vs. Globe vs. Butterfly, etc...).
More specifically I'm looking to identify pros and cons, throttling requirements, susceptibility to leakage, restrictions due to service (selection based on fluid properties/state), cost, etc...
Also, can we specify TSO (Tight Shut Off) on any type of valve and are some valves better for hazardous service (H2S, CO2, and so on) requiring TSO?
Appreciate any comments.
Valve Selection
Started by Enginerdo, Mar 21 2011 03:14 PM
Posted 21 March 2011 - 03:14 PM
Posted 21 March 2011 - 08:56 PM
As a starting point, see:
http://www.cheresour...m/valvezz.shtml
and
http://webwormcpt.bl...to-control.html
and
Edited by sheiko, 21 March 2011 - 09:00 PM.
Posted 22 March 2011 - 02:51 AM
Hi enginerdo,
You can find it on Valve Selection Hand Book by Peter Smith & R. W. Zappe
I attached the valve selection chart extracted from the handbook
Posted 23 March 2011 - 02:52 AM
Take a look at this paper.
hope this helps
hope this helps
Posted 23 March 2011 - 07:45 AM
These are all good references. But these are basic type of valves only. You should try to understand WHY a valve is good for certain servics and characteristics so that when "specialty" valves are presented, you can understand their capabilities and limitiations. A few I can think of are V-port Ball valves Hemi-leptical valves, Quarter-trun Offset valves, just to name a few that try to combine the benefits of the various types basic valves.
Scott
Scott
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
