I need assistance in coming up with the "pump curve" for an Aurora type 344A centrifigal suction pump ... size 6"x6"x9" ... 840 gpm ... 72 ft Head ... 1750 rpm ... 20 hp motor ... I am on a community recreation commisision which was asked by the local Health Dept. to come up with the "pump curve" for our system ... I've been doing some looking into the terminology etc. on the net BUT not being a chemical engineering student or engineer I haven't the foggiest idea what is going on ... the Health department sent 5 suits to the pool ALL saying we had to have a "pump curve" what ever that is ... can someone please help with my dilema ...
Pump Curve Calculation
Started by Guest_pfloyd_*, Jun 30 2005 06:51 PM
Guest_pfloyd_*
Posted 30 June 2005 - 06:51 PM
Posted 30 June 2005 - 09:08 PM
pfloyd:
If you're not even an engineering student, you are going to go through hell trying to understand any definition of a pump curve I can pass on to you, but here goes:
A "pump curve" is, in reality, a Pump Performance Curve. This curve is a plot of the flowrates a centrifugal pump can deliver at a variety of total developed heads. What it tells you is the flowrate that corresponds to a given total developed head. It also plots the efficiency of the centrifugal pump at a given point, the developed brake horsepower, and the Net Positive Suction Head (NPSHr) required at that flowrate point.
Now, you're probably worse off than you started out at, since you probably don't know what the above terms all mean and what their significance is. Don't be embarrassed; many engineers also don't know. To understand and know these terms requires several courses in Fluid Mechanics plus some years of hands-on engineering in the field. We certainly can't cover or make up for that in one forum thread.
I recommend you get in touch with Aurora Pumps - if they are still in operation - and ask them for a copy of the pump you presently have. You'll need to identify the model and serial number in order for them to help out. I've used many of their pumps in the past and I think the one you have is a turbine regenerative type, which is a small flow- high head pump.
I hope this information helps you obtain what you are looking for.
Posted 01 July 2005 - 02:23 AM
Some 5 minutes of searching on the web gave the following result: http://www.aurorapum...ves_340_360.pdf
Your curve is on page 35 (=catalog page 432), the upper graph, curve for impeller diameter 8.75"
Guest_Guest_*
Posted 01 July 2005 - 08:30 PM
... gvdlans/Art Montemayor ... thank you both for the replys ... just as you posted AM - I'm totally lost BUT I will take hard copies of what you both have given me to the city water plant engineer - hopefully he will be able to make sense out of the info you have provided to me ... greatly appreciated ...
pfloyd
pfloyd
Posted 02 July 2005 - 12:36 PM
No thanks. Please keep us informed...
