I am searching for a recommendation on a pump to be used for hydrogen peroxide (35%) service in an industrial application. Our old pump has been problematic and is to be replaced, but I want to replace it with something more reliable.
Does anyone have experience with a particular brand that could be recommended ?
Thanks,
Steve
35% Hydrogen Peroxide Pump
Started by srwilkinson, Jul 08 2005 12:59 PM
Posted 08 July 2005 - 12:59 PM
Posted 27 July 2005 - 09:25 PM
What type of pump are you looking at? Transfer application?
Material - teflon?
I've experience using Prominent dosing pump to dose H2O2 50% without any problem for 3 years now.
Material - teflon?
Posted 22 December 2007 - 08:53 AM
QUOTE (MH.C @ Jul 27 2005, 09:25 PM) <{POST_SNAPBACK}>
Material - teflon?
Material - teflon?
I have a similar application requirement to pump (Dose) 50% H2O2 in a chemical reactor system.
What type of pump have you been using? Teflon MOC? Is it a motor driven Prominant diaphragm pump? Do you control H2O2 dosing by a VFD motor drive?
Posted 02 January 2008 - 10:30 AM
QUOTE (srwilkinson @ Jul 8 2005, 05:59 PM) <{POST_SNAPBACK}>
Thanks,
Steve
Thanks,
Steve
Steve,
first of all, please give the desired base values, as output and head.
I have experince with 4 years old system for 50% H2O2, where two pumps, 1,5" Sand Piper (as unloading pump) and Jesco Dosiertechnik (as dosing pump) are working well.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
