In compressor station design, it is mandatory that the gas entering the centrifugal compressor should be free from dirt, solid particles and liquid droplets. I am involved in booster compressor stations design project. In the design, we considered the following arrangement for the process gas flow to the compressor during normal operation:
Natural gas from pipeline – Dry gas filters (operational during plant start-up and for a period of time before its taken offline) – Cyclone separator (Gasunie type) – Compressor suction flange.
The cyclone separator (2 per train) was chosen because it gives us economical viable vessel due to the volume of gas is expected to handle per train. The conventional scrubber design gives a larger vessel dimension. Each compressor train handles an estimated gas flow of 1,359,000 kg/hr.
Please, I need technical input on the separation efficiency of cyclone separator, its minimum pressure drop across the vessel, etc.
Cyclone Separator
Started by asade abiodun, May 24 2011 02:51 AM
Posted 24 May 2011 - 02:51 AM
Posted 24 May 2011 - 03:43 AM
Asade,
Following links can give you an insight into cyclone efficiency and pressure drop:
http://pas.mnsi.net/brochure.htm
http://www.enq.ufsc....313/cyclone.xls
Additionally for pressure drop and efficiency calculations in detail refer:
Chapter 4, Equipment Sizing, "Fortran Programs for Chemical Process Design, Analysis and Simulation" by "A Kayode Coker"
Hope this helps.
Hope this helps.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Types Of Cyclone Function In Large Flow RateStarted by Guest_alaasleem2026_* , 03 Sep 2024 |
![]() Discharge Scrubber And Suction SeparatorStarted by Guest_Falah_* , 21 Jul 2024 |
