Guys,
Which EOS is better to be used for Natural gas and why?
I read PR is better as it predicts Liquid densities better than SRK?
Say if you run process simulation in HYSYS one is going to use PR; is this correct?
Eos For Natural Gas
Started by awesome, Jun 01 2011 03:25 AM
Posted 01 June 2011 - 03:25 AM
Posted 02 June 2011 - 12:14 PM
Using any of the two will yield good results. Peng-Robinson is considered more accurate as it has been continuously updated and upgraded with experimental values, at least according to the software developers.
Posted 04 June 2011 - 04:33 AM
In the past PR was considered capable to model better fluids with higher acentric factors (while SRK the best for methane etc.) but now with TWU, Mathias etc. extended Alpha functions this is not true and both can produce very accurate results, check that your sofware does include one of these extended correlations (by the way my sofware has the three TWU parameters for almost all the fluids in database)
Posted 03 September 2011 - 02:14 PM
The new version of HYSYS also has GERG which is very accurate for predicting liqui density
Posted 05 December 2011 - 02:42 PM
When detailed laboratory analysis is available a common practice is to input those data in software package
however, as no one knows what happens between two successive laboratory measurements the calculated values may be unreliable.
Apart from this a software package offers the advantage to calculate a large number of different properties with great accuracy.
a suitable equation of state (Peng Robinson, Soave Redlich Kwong , GERG or others) can calculate very accurate VLE values, for hydrocarbon mixtures typical errors are whithin 1-2 C of measured values.
For values as density AGA or GERG again are very accurate (typical errors < 0.3%).
Edited by DOXA, 05 December 2011 - 02:43 PM.
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
Heating Of Natural GasStarted by Guest_kaidlut_* , 01 May 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
