Steam Stripping
Posted 03 June 2011 - 03:46 PM
I will be thankful if anyone can enlighten me on this.
Phukan
Posted 04 June 2011 - 10:06 AM
I wanted to know the calculation basis for the quantity and quality of steam required for the purpose of steam distillation and stripping. How much degree of superheat is normally desired for the purpose of stripping. which one is more economical in terms of the stripping effect, increasing the steam mass or its temperature. While handling a crude with high percentage of light ends is it advisable to have a higher degree of superheat and decrease the steam flow rate to have get same distillation effects, considering the fact that overhead exchangers are limiting the vapor handling load.
Phukan
You need to study nelson and watkins, you will get your answer in these book and lot more about distillations.
Toor
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
