C Factor
Started by Rakesh Budithi, Jun 06 2011 08:51 PM
Posted 06 June 2011 - 08:51 PM
I would like to know in detailed about C Factor. How does it effect my Gas oil product quality?
Posted 06 June 2011 - 10:14 PM
Rakesh,
We ourselves would like to have an introduction on 'C' factor before any one of us attempts to answer your query. I know quite a few 'C' factors in O&G industry and hence would you be kind enough to explain what 'C' factor are you talking about.
Posted 07 June 2011 - 02:34 AM
Ankur,
Thanks For Your Reply,
I'm talking about the C-Factor in Gas-Liquid Operation, which in connection with entrainment of liquid. I just want to know how it changes with my packing structure, feed distributor and wetting rate and etc.,
Posted 07 June 2011 - 09:12 PM
Liquid entrainment by the vapor is indeed an important sizing factor in distillation columns.Ankur,
C Factor = Vs * square root [(density of vapor) / (density of liquid - density of vapor)]
With, Vs = superficial gas velocity
Thus, C factor has a velocity unit.
See also:
http://www.cbu.edu/~...s/distill7.html
http://www.chemsep.c...ystemFactor.pdf
and attached document.
Edited by sheiko, 07 June 2011 - 09:42 PM.
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
![]() Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
![]() Environmental Factor "f" Calculation In Psv Fire CaseStarted by Guest_mahmooddalvi09_* , 17 Aug 2024 |
![]() Wind Enhancement Factor In Kumana Kothari CalculationsStarted by Guest_rlepra_* , 01 Dec 2017 |
