For laminar flow pressure drop for flow through a pipe is directly prportional to velocity while it is prportional to square of the velocity in case of turbulent flow which is better from various aspects.
regards
Laminar Vs Turbulent Flow In A Pipe - Which Is Better?
Started by rsk, Jun 22 2011 10:32 PM
Posted 22 June 2011 - 10:32 PM
Posted 23 June 2011 - 11:24 AM
The most important aspect is economic! Other aspects will influence the economics like power required to pump the fluid, capital cost of the installation, big piping for lamoinar flow, small piping for turbulent flow, maintenance costs, etc.
Posted 16 August 2011 - 04:00 PM
Hi, cmiiw, Usually we want to optimize the line size vs capacity. We want to transfer as much as fluid possible (limited by pressure drop, errosional velocity, vibration, noise, etc) with the lowest line size. Thus, most of the time it will be in turbulent region. But, that does not mean that turbulent region is better than laminar.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
