Hello Everyone,
Anyone processing ESPO( East Siberian Pacific Ocean) Crude oil blend? Just in case you are, appreciate if you can share operational issues and concerns experienced in processing ESPO crude. In our case, we have seen signs of accelerated fouling in pre-heat exchangers due to high BS&W. We limit mixing to our crude mix to about 45%. Appreciate to know your experience in ESPO processing.
Espo Crude Processing
Started by Vivienne, Jun 26 2011 08:24 PM
Posted 26 June 2011 - 08:24 PM
Posted 29 August 2011 - 09:25 AM
Vivienne,
My refinery never goes that high in processing ESPO. By about 34% ESPO in mixed crude we already observed significant decrease in pH of CDU overhead receiver water bootleg (since it happened before we equipped our unit with proper corrosion inhibitor injection, the pH could be as low as 3,5. By proper corr. inhibitor injection, it shouldn't be a bi problem). Our refinery was designed for processing sweet crude with S<0,2%, so processing ESPO whose S=0,6% is quite challenging. All straight run products has higher sulfur content but it could be accommodated in our treating units to achieve on specification product. About one or two times we got cu strip as high as 2C in our butane product (whose feed come totally from CDU overhead system), there shouldn't be a problem if you has butane or mix LPG treating unit (such as KOH treater).
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Quantitative Risk Assessment Of Onshore Crude Oil PipelinesStarted by Guest_Mansi_* , 14 Feb 2024 |
Crude Oil Storage CapacityStarted by Guest_Noman97_* , 19 Jan 2024 |
![]() Sand Handling And ProcessingStarted by Guest_Kakashi-01_* , 23 Jun 2023 |
