Efficiency Of The Refrigeration Unit
#1 Acronics
Acronics
Posted 12 July 2011 - 08:17 AM
Hi, i have a refrigeration unit consist of Refrigeration compressor, Refrigerant condenser and Economiser. I want to calculate the overall efficiency of the system. I have the design data (temperature and pressure across everything) but don't know any formula or method to calculate the efficiency.
  • Attached File  pic1.JPG   590.54KB   31 downloads
#2 rkgupta
rkgupta
  • 4 posts
Posted 12 July 2011 - 01:04 PM
I advice, please read a good book of refrigeration and air conditioning.
#3 vijji
vijji
  • 26 posts
Posted 13 July 2011 - 04:07 AM
Use the formula of Q = m x Density x Cp x Delt T.
Where
m=mass flow rate (Can be calucalted by taking equal size tapping on outlet line and measure physically) m3/hr.
Cp=Specific heat of used brine solution Kcal/Kg Deg.C.
Delt T=Temperture difference across the chiller in Deg.C.
After getting Q , divide with 3024, can get in TR, compare the value with actual rated capacity.
#4 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 13 July 2011 - 10:18 PM
Attached thumbnail looks blurred, numbers are not legible. Can you give a clearer drawing or sketch?
#5 pavanayi
pavanayi
  • 258 posts
Posted 14 July 2011 - 03:22 AM
Acronics,
You might also want to read about 'Coefficient of Performance (COP)' used in context of refrigeration systems.
#6 Hamidihizami
Hamidihizami
  • 9 posts
Posted 18 July 2011 - 08:13 PM
I recommended you to read this. I download it from internet. I hope this will help you :)
