We provide minimum flow lines to protect the pump from running dead headed.My understanding is that we can achieve it by providing control valve or an orifice. In case of orifice the pump capacity gets larger to accomodate the min flow and power is wasted.
Can somebody please clarify if min flow is required for On/Off pumps. Pumps running at high level and stopping at low level.
thanks
Minimum Flow Circulation Line For Centrifugal Pumps
Started by processji, Jul 15 2011 01:34 AM
Posted 15 July 2011 - 01:34 AM
Posted 15 July 2011 - 03:40 AM
Let you consider this resource .
Hope this helps
Hope this helps
Posted 15 July 2011 - 03:46 AM
It is required, if this intermittent operation lasts long enough for the pump to be overheated in case of an inadverted valve closure at the discharge. Nature of pumped liquid (flammable or not) plays a role in the decision. Look at previous thread http://www.cheresour...h__1#entry44445 for a more detailed picture.
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Nitrogen Flow Meter Dp Type ErrorStarted by Guest_Ranga v_* , 18 Jun 2026 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
