Phast Modeling
#1 areads
areads
  • 19 posts
Posted 21 July 2011 - 10:47 AM
Does anyone know how to use PHAST consequence modeling? I need some help please!
Thanks.
#2 acer_asd
acer_asd
  • 28 posts
Posted 21 July 2011 - 11:05 PM
Thanks.
What kind of help are you expecting here?
I mean you want to learn from scratch or you are having some problem with phast.
#3 demank
demank
  • 150 posts
Posted 22 July 2011 - 08:18 AM
I think PHAST is already user-friendly with the button of HELP..,
#4 areads
areads
  • 19 posts
Posted 01 August 2011 - 07:24 AM
I am modeling a flaring case where the flare fails to ignite, and I am kind of teaching myself (no other way at the momemnt!). I have used the jet fire model, so my first question is, is this the correct way of doing it?
My second question is related to the interpretation of the graph. If from the results that I got, I wanted to establish a "no-go" sterile radius, based on the yellow contour (6.3 kw/m), how do I read the graph? please see attached.
Many thanks for your help.
#5 adammusthafa
adammusthafa
  • 8 posts
Posted 16 August 2011 - 03:18 PM
Hi, correct me if i am wrong. To me, if you are simulating a failure in ignition, what you should simulate is the gas dispersion at 100% lfl. This is to check the extend of your flammable gas dispersion which you fail to burn at the flare.
Jet fire module usually used to simulate a leak from a containment which are pressurized. If you want to simulate flare radiation, it is better to use flaresim, onsteaf of phast.
In jet fire module, the graph shows you isoradiation contour relative to the source.
