Hi everyone,
Can anyone teach me how to simulate a deaerator using HYSYS?
Deaerator
Started by jpm.chem, Aug 14 2011 07:08 AM
Posted 14 August 2011 - 07:08 AM
Posted 16 August 2011 - 12:03 PM
Hi everyone,
Deaerator operation can be calculated by mass and energy balances using the steam tables. The feedwater must be heated in the deaerator to its saturation temperature in order to liberate the problematic dissolved gases (carbon dioxide and oxygen). You can figure out using the steam tables how much flow of your steam supply is required to do this.
Most systems typically have a deaerator and downstream injection of an oxygen scavenger to eliminate any residual oxygen from the feed water.
What are you trying to determine? The expected ppm of oxygen left in the feed water?
![]() High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
![]() Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
Deaerator Equipment In BoilersStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
![]() Basic Principles For Designing A Vacuum Deaerator For SeawaterStarted by Guest_gohar.m_* , 19 Jul 2017 |
Deaerator Internals DesignStarted by Guest_jaivanthrao_* , 17 May 2017 |
