Is there any code/standard regarding location of Ammonia storage tank in a Ammonia/Urea complex?The storage
tank's capacity is 10000MT & it has a dike around it as per code.What is the minimum distance to be maintained between the tank & plant equipment/machineries(compressor/gas turbine/power plant/reactors etc.)?We didn't find any rule for this.But in our older Plants it is More than 50M away from plant machineries.For land restriction in our new proposed plant we have to locate it closer to plant equipment.
Location Of Ammonia Storage Tank In A Ammonia/urea Complex
Started by tarafdar, Sep 10 2011 01:09 AM
No replies to this topic
Posted 10 September 2011 - 01:09 AM
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
