sorry to bother your all this trivial.
Thermal expansion : a process fluid result from energy absorbed from an external source.
The increase in fluid temperature brings about a decrease in density and an
increase in pressure that may require the provision for thermal relief.
The energy source may be a high temperature process stream or a relatively cool
source such as ambient heat gain. In certain instances, such as with cryogenic fluids
(LNG, ethylene, or ethane for example) or chlorine liquid, provision for thermal relief due
to ambient heat gain may be required.
The analysis of a thermal expansion scenario will fall into one of the following three
categories: (1) simple hydraulic expansion with a liquid only relief,
(2)thermal expansion of a liquid with vaporization at relief conditions,
and (3) thermal expansion of a compressible vapor.
Thermal expansion relief valves are required in liquid-full systems if the system can be blocked in and/or subjected to heat input from the atmosphere or process that results in overpressure.
The question is below (please see attached file):
Q1.Is PSV set pressure should follow the design pressure that the equipment be protected (in this example Heat exchanger DP= 22 kg/cm2g)
or follow the downstream header pressure design pressure(in this example hot oil return header = 11kg/cm2g)
Q2.This Heat exchanger located around 7 m. Is the fire case scenario or thermal expansion scenario should be considered? But, in this example, the fluid(hot oil) will not vaporized
and hence thermal expansion of a liquid with vaporization may not be in the consideration.
Q3. About thermal expansion case, is the method in my post attachment correct or could you please provide more clear shortcut method for solving this case?
Thank you so much.
