I want to check an existing horizontal vessel size due to increasing liquid flow rate. The vessel is simply a degasser and has no mist eliminator. In the GPSA section 7 I assumed a particle size and calculated the terminal velocity. I then used this terminal velocity in the following equation:
L = 4Qa / 3.142VtDv. However this equation assumes no liquid retention and I need to have a 50% liquid level in the degasser. How do I now modify the diameter to use in this equation ( I assumed half of the crosssectional area and calculated a dimater based on this - is this a valid assumption?)
Also in vessels with mist eliminators there is a maximum allowable vapor velocity criteria using a K factor. Is there a recommended range of K factors for vessels without demisters??
Separator
Started by CRB, Aug 18 2005 12:54 PM
Posted 18 August 2005 - 12:54 PM
Posted 18 August 2005 - 06:34 PM
CRB:
In regard to the above question, I believe you are asking about the K factor to be used with the Souders-Brown equation. The GPSA Engineering Data Book recommends the following k values for vertical drums with horizontal mesh pads (at the denoted operating pressures):
0 psig: 0.35
300 psig: 0.33
600 psig: 0.30
900 psig: 0.27
1500 psig: 0.21
GPSA Notes:
1. K = 0.35 at 100 psig; subtract 0.01 for every 100 psi above 100 psig
2. For glycol or amine solutions, multiply above K values by 0.6 – 0.8.
3. Typically use one-half of the above K values for approximate sizing of vertical separators without mist eliminators.
4. For compressor suction scrubbers and expander inlet separators, multiply K by 0.7 – 0.8
Although the GPSA recommended factor are for vertical drums, they may also apply to horizontal drums.
QUOTE
0 psig: 0.35
300 psig: 0.33
600 psig: 0.30
900 psig: 0.27
1500 psig: 0.21
GPSA Notes:
Posted 18 August 2005 - 07:42 PM
I've heard that there are some "high efficiency" demisters that claim to enhance droplet removal beyond that achieved with conventional mesh or chevron elements. A former coworker told me that with these devices one could effectively increase the K factor beyond 0.35 (Imperial units) which I've always thought of as a maximum. I'd be interested in any comments on this topic and also a description of any enhanced approaches to demisting. What K values can be attained?
Doug
Doug
Posted 20 August 2005 - 07:27 PM
QUOTE (djack77494 @ Aug 19 2005, 01:42 AM)
Doug
Doug
I have read in the litterature of mist eliminators manufactrers that some devices can have a k factor of 0.65 such as vane pad type with horizontal flow invertical drums. Also I am interested to know how to calculate the spacing in the vessel between the mst eliminator and the inlet and the outlet nozzles.
best regards,
Lazreg
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Discharge Scrubber And Suction SeparatorStarted by Guest_Falah_* , 21 Jul 2024 |
![]() Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
