I have two traival question need to bother:
Q1.I always misuse the wrong temperature and pressure in
the wrong class pipe. For example, operating pressure 23kg/cm2g
OT=208C, DP=28kg/cm2g DT=300C can't be fitted in the carbon steel
piping.
I wonder that anyone can kindly share any easy-to-read graph for any materail's
PIPING FLANGE RATINGS in different temperature and pressure condition.
Q2. How to judge the pump piping dessign pressure guide rule(attachement).
Suction piping of parallel pumps (downstream of block valve) must be good for the discharge side maximum
operating pressure when valve is closed
Equipment Downstream of Centrifugal Pumps:
Piping - design pressure for piping must be consistent with the design pressure for vessels and
equipment to which it is attached.
How to define the design pressure between pump casing and downstream control valve?
The rule write : DP = Max Suction Pressure + Pump Shutoff P, but I always used shut off pressure of pump
for design pressure of downstream pipe before.
And, the following confuse me more:
From Downstream Control Valve to Last Block Valve:
1.If closing valve can Directly result in max suction pressure:
DP = Max Suction Pressure + Pump Shut-in P
2.If closing valve does not Directly result in max suction
Pressure:
a. DP = Normal Pump Suction Press + Pump Shut-in P
b.DP = Max Pump Suction Press + Normal Pump P
Please help me out how to explain this rule more detail.
Thank you very much.
