I am studying in final year of Chemical Engineering..
I am assigned the project; "Case Study and Designing Of Vacuum Distillation Unit"...
I am very much nervous that from where should i start the project....as far as i am concerned my main focus is on designing of the column mainly....Really need help regarding the column internals design and various factors and equipments involved in it ....And i am an average student so kindly neglect my foolish questions... i will be very much thankful if anyone can help me out on this one...
Muhammad Tanzeel Usman
Final Year Project !
Started by Tanzeel, Sep 21 2011 02:53 PM
Posted 21 September 2011 - 02:53 PM
Posted 22 September 2011 - 10:53 AM
Pllzzzzzzzzzz anyone .. Kindly help me in this regard.. I will be very much thankful to you !!
Posted 26 September 2011 - 04:45 AM
You need a better title than "Final year project!"
I suggest you repost as "Case Study and Designing Of Vacuum Distillation Unit"...
People hate opening posts where they have no idea what the post is about.
Posted 26 September 2011 - 07:32 AM
Did you try google : Vacuum distillation unit ? A lot of stuff there .
http://www.google.co...iw=1150&bih=636
You should also consider this book : Distillation design by Henry Z Kister , it should help
Posted 28 September 2011 - 02:57 AM
Hi
The main difference for vacuum distillation is the need to have vacuum pump or steam ejector at the overhead system. This is to create the vacuum required for the distillation. Other possibility is that you may need to install overhead chiller depending on the dew point of the overhead stream. The others e.g the internal parts such as tray or packing, will be the same as pressurized distillation.
Any text books on distillation which I believe you have a lot of them in the University's library. Website and textbook suggested by BREIZH are good resources.
Design Of A Psa Unit For Undergraduate Design ProjectStarted by Guest_LMorgan14_* , 04 May 2021 |
Superheated Steam Project DesignStarted by Guest_brazilianmecstudent_* , 18 Oct 2022 |
Problems With ProjectStarted by Guest_JArchy123_* , 07 Jan 2022 |
Answered
Design Of A Shell & Tube Condenser For Undergraduate ProjectStarted by Guest_DavidSJO_* , 09 May 2021 |
Elimination Of Final Stage SeparatorStarted by Guest_Danish John Paul_* , 13 Nov 2020 |
