hi guys
i have a problem about that
i have line with 82 km length from offshore @ 140 bar 40 C degree
recevied to onshore @ 81 bar 20 C degree
i have gas + condensates compositions and molar flow (1620 MMSCFD)
required:
1) Stop offshore production and calculate how long it will take to depressurize the line from 140 bar to 81 bar then from 81 bar to 1 atm , so i need the Equations to solve this problem
2) how can do that problem by HYSYS 3.1 from utility ( i know it should be 15 min but here in may case the time is required to calculate
any on can help me ?? as possible as fast plz
Offshore Line Depressurize
Started by Guest_Rashid_*, Aug 23 2005 03:59 PM
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
Top Foam Pourer Line- Reducer ConnectionsStarted by Guest_RAFAELDAVE_0752_* , 03 Sep 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
