Hysys - Dynamics Mode
#1 morphzin
morphzin
Posted 28 September 2011 - 09:47 PM
i have some problems with the dynamic mode on Hysys. I am new in Hysys and I can't simulate the process of unloading a tank. When i try to do that hysys comes with a negative flow in one of output stream. Can somebody help me with this?
#2 himant
himant
  • 53 posts
Posted 02 October 2011 - 02:56 PM
can you elaborate your problem?
#3 morphzin
morphzin
Posted 02 October 2011 - 04:54 PM
I wanna simulate the process of unloading a tank full of glp and water, but i dont know how to do that because i have to put a feed stream. If any one have some tutorial for dynamic mode, please gimme the link!
#4 Technical Bard
Technical Bard
  • 407 posts
Posted 02 October 2011 - 08:40 PM
You need to set up the model with a feed stream to fill the tank - then close the inlet valve so that flow into the tank stops when it reaches the "full" level. Then run the model with the outlet opened and it should empty the tank. You can also initialize the model manually, but I find it is easier to do it this way (that way you don't have to figure out how to enter the composition of the material in the tank.
#5 henrylcl
henrylcl
  • 3 posts
Posted 03 October 2011 - 08:47 PM
Hello to all,
May i get some help from you all about gas hydrate prediction below 0 degree celcius. I am now doing the gas hydrate prediction project and now is using the HYSYS. I am able to predict the formation pressure by give the input of temperature in HYSYS. But, not for temperature below 0 C, as the result just indicate "Ices form first" without stating the formation pressure.
May i know someone who is familiar with hysys can suggest a solution for me. During the process, i just provide a feed with composition of methane, water and CO2,together with condition of temperature ,molar flow and pressure. i get the result by clicking on "performance - add utility (hydrate formation utility) to see the formation pressure.
#6 zinokabyl
zinokabyl
  • 4 posts
Posted 05 October 2011 - 01:17 PM
Hi I'm a bignner in hysys
first for the problem of dynnamic tank problem
you've to size well the tank, because before changing from the steady state to dynamic stad you've first add valves, PID, and sizie well the tank
after run dynamic model (integrator)
if you've solved the problem please tell us
good luck
#7 zinokabyl
zinokabyl
  • 4 posts
Posted 05 October 2011 - 01:21 PM
please Mr henrylcl
could you please give me the fractions of the compounds (mole, mass...) flow, pressure; and tempreture ????? please
I'll try to use my recent version of hysys 7.1 and I look forward to get solution
thankx in advance
