Posted 16 November 2011 - 05:36 PM
Posted 23 November 2011 - 04:07 PM
1. Data for sun & earth.
Mass: Sun 2E30 kg, Earth 6E24 kg
Diameter: Sun 1400E6 m, Earth 12.74E6 m.
Average specific gravity (water = 1.0): Sun 1.4, Earth 5.5
Surface temperature: Sun ~6000 oK, Earth 288 oK.
Center temperature: Sun ~19E6 oK, Earth ~5700 oK
Specific gravity at center (water=1): Sun ~108, Earth ~13 (crust ~ 2.5).
Composition: Sun H=65%, He=30%, heavier elements=5% (varies per interpreting theory). Earth Fe=32%, Si+Mg=29%, O=30%, S=3%, other=6% (w/w).
Concerning Sun, temperature conditions are quite stable. All energy produced is emitted at a rate of 3.7E26 W (quasi-static process). Sun surface area is π*(1400Ε6)^2= 6.16E18 m2, and Stefan-Boltzmann law for black body radiation at 6000 oK predicts 5.67E-8*6000^4=73.48E6 W/m2. So heat radiated from Sun (all wavelengths) is estimated at 6.16E18*73.48E6=4.5E26 W, little differing to published 3.7E26 W.
1.1 Due to extremely high temperatures, sun’s matter behaves as an ideal gas composed of particles (nuclei & electrons). According to this principle:
5626Fe is composed of 1 nucleus & 26 electrons, avg atomic weight As= 56/27=2.07.
168O is composed of 1 nucleus & 8 electrons, As= 16/9=1.8
Average atomic weight of all particles (except from H & He) As~ 2.0
11H is composed of 1 nucleus & 1 electron, avg atomic weight As= 1:2=0.5
42He is composed of 1 nucleus & 2 electrons, As= 4/3=1.3
Average atomic weight of all sun particles As~1.0.
If temperature & pressure were uniform, above data would give P/T=116 bar/oK (R=0.083145 m3bar/oK/kgat). This is indicative of the huge pressures inside sun, where gravity is balanced off by thermal collisions of particles.
For a star to be thermally stable, its mass should approximately be > 0.5*M (otherwise no shine) and <5*M (otherwise it shall explode), where M = Sun mass (2E30 kg). Common stars have mass <2*M and temperatures close to that of Sun.
For stars similar to Sun, temperature is proportional to mass and inverse to diameter. E.g. Sirius with mass 2.4*M and diameter 1.8 of Sun, would have temperature in oK 2.4/1.8=1.3 times that of Sun.
1.2 Sun is generating heat by thermonuclear fusion of H at 10E6 oK ( http://en.wikipedia.org/wiki/Star). H is converted into He at a rate of about 180E9 kg/s to generate the emitted heat, as attached “sunfusion.xls” indicates.
Heat generation mechanism changes to He conversion into C (at 100E6 oK), when the star gets a Red Giant at the end of its life, as it shall occur with Sun after ~5E9 years. Even in that age, there can be periods of “temporary” reverting to H fusion ( http://en.wikipedia.org/wiki/Red_giant).
2. Sundry info of recent years.
2.1 Few scientists have expressed concern that particle collisions implemented by strong modern accelerators (e.g. Kern Collider in Switzerland) could create a new Universe! The answer by RAM (main reference of previous post) was that what has not been created in 12 billion years is quite improbable to happen now. Another article in the bulletin of Technical Chamber of Greece suggests that accelerated particles do not have energy adequate to initiate such a formation.
2.2 As previous post says (17 Nov 11), even black holes can be “evaporated” withing huge time intervals (e.g. 1E60 years) through Hawking radiation emitted from them. Co-existence of a particle with its antiparticle is probable everywhere, even in the vicinity of black hole. But there the two virtual particles accept energy and become “real”. In case that the antiparticle falls inside and the particle outside, the black hole has already lost some energy. Due to stronger gravity, big black holes are “evaporated” more slowly than small ones.
2.3 The cyclic model of an oscillating Universe (expanding, then contracting, and so on) was expressed in 1930s. The big bang would be followed by the big crunch. The idea was abandoned, but revived recently in more complex versions, one of which estimates a cycle period at ~1E12 years. It is related to dark energy, an unknown form of energy to rule Universe. More on http://en.wikipedia...ki/Cyclic_model.
Note: Above is collected from school physics, as well as "New Encyclopaedia of Helios" (in Greek) - "The Universe" (Athens, ~1979).
Wikipedia is again a good reference for supplementary info.
Edited by kkala, 23 November 2011 - 05:09 PM.
Posted 16 December 2011 - 08:27 AM
Posted 22 December 2011 - 07:09 PM
For Chemical Engineers cosmology is within their theoretical interests. Stars produce energy through nuclear fusion. Sun and planets reminds nucleus and electrons.
Edited by kkala, 23 December 2011 - 06:32 PM.
Posted 24 December 2011 - 02:52 AM
Posted 24 December 2011 - 04:23 AM
It was surprising to know as a student that light traveling in the proximity of Sun has a slighly curved flight, indicating that photons (http://en.wikipedia.org/wiki/Photon) can behave as particles of very small mass.
Posted 07 January 2012 - 12:46 PM
To my information, space telescopes was the last word of technology some years ago. Now these telescopes on earth manage to have a clear picture, using interferometry, as explained in http://en.wikipedia..../Interferometry.
