Following recycled lines which commonly used in process plants for pumps:
- The orificed bypass,
- The control valve in bypass line
- A combination check valve/bypass valve.
Any help is much appreciated.
Posted 20 November 2011 - 08:02 AM
Posted 20 November 2011 - 08:29 AM
Posted 20 November 2011 - 08:46 AM
Posted 20 November 2011 - 10:21 AM
Posted 21 November 2011 - 02:28 AM
Dear Ankur,
Thanks for your swift reply.
I see all of mentioned links , but for your information; in EXXONMOBIL's design practices for pump (installation facilities) is referred to power of pump ( recommended orifice for below 38 kw and above it to use control valve) ,I want to know is there any recommendation in your side for using each of them ?
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
