Hey,
How do you determine the slug volume in PIPESYS. I have created a oil system in HYSYS using PIPESYS. I have oil flowing from a separator at each well to a pipe system at similar pressures and temperatures. Essentially each well flows to a north gathering and to a south gathering system that tie into a common header to an oil battery. Each pipe is 3" with the appropriate elavations and lengths. Also, each inlet stream is pure liquid entering the pipeline, where any dissolved gas leaves the liquid stream when the pressure is decreased (as fluid moves across the pipe system).
I am wondering how to find the slug volume at the end of the pipe system (oil battery) in PIPESYS. At this point there is a vapour fraction of about 0.025.
Thanks for the help,
Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
Partial Volume Of Bi-Lobe TankStarted by Guest_bangzhuqiao_* , 16 Oct 2024 |
Separator Sizing And Selection, And What Is Slug?Started by Guest_Doneisbetterthenperfect_* , 26 Jan 2024 |
Pipesys (In Hysys) Cannot Comprehend Pressure, Temperature & VelocStarted by Guest_IonCube_* , 15 Oct 2017 |
Aspen Hysys Simulation Issue With Pfr Reactor Volume: Seeking AdviceStarted by Guest_naduken_* , 27 Apr 2023 |
