Flash Drum
Posted 08 September 2005 - 02:48 PM
Thanks for all the help, mike
Posted 08 September 2005 - 05:26 PM
A vapor-liquid separator drum is a vertical vessel into which a liquid and vapor mixture (or a flashing liquid) is fed and wherein the liquid is separated by gravity, falls to the bottom of the vessel, and is withdrawn. The vapor travels upward at a design velocity which minimizes the entrainment of any liquid droplets in the vapor as it exits the top of the vessel.
The size of a flash drum (or knock-out pot, or vapor-liquid separator) should be dictated by the anticipated flow rate of vapor and liquid from the drum. The following sizing methodology is based on the assumption that those flow rates are known.
Use a vertical pressure vessel with a length-to-diameter ratio of about 3 to 4, and size the vessel to provide about 5 minutes of liquid inventory between the normal liquid level and the bottom of the vessel (with the normal liquid level being at about the vessel's half-full level).
For the maximum design vapor velocity (which will set the drum's diameter), use the Souders-Brown equation:
Vmax = (k) [ (dL - dV) / dV ]^0.5
where:
Vmax = maximum design vapor velocity, ft/sec
dL = liquid density, lb/ft3
dV = vapor density, lb/ft3
k = 0.35 (when the drum includes a de-entraining mesh pad)
0 psig: 0.35
300 psig: 0.33
600 psig: 0.30
900 psig: 0.27
1500 psig: 0.21
GPSA Notes:
1. K = 0.35 at 100 psig; subtract 0.01 for every 100 psi above 100 psig
2. For glycol or amine solutions, multiply above K values by 0.6 – 0.8.
3. Typically use one-half of the above K values for approximate sizing of vertical separators without mesh pads.
4. For compressor suction scrubbers and expander inlet separators, multiply K by 0.7 – 0.8
The drum should have a vapor outlet at the top, liquid outlet at the bottom, and feed inlet at somewhat above the half-full level. At the vapor outlet, provide a de-entraining mesh section within the drum such that the vapor must pass through that mesh before it can leave the drum. Depending upon how much liquid flow you expect, the liquid outlet line should probably have a level control valve.
As for the mechanical design of the drum (i.e., materials of construction, wall thickness, corrosion allowance, etc.), use the same methodology as for any pressure vessel.
Posted 08 September 2005 - 08:24 PM
Posted 08 September 2005 - 10:16 PM
Your original posting said that you knew the flow rates of all the streams. Thus, I assume that you know the cubic feet per second of vapor (V) that will be leaving from the top of the flash vessel. Thus, the cross-sectional area (A) of the vertical flash drum will be:
A, ft^2 = (V, ft^3/sec) ÷ (Vmax, ft/sec)
Knowing the cross-sectional area A in square feet, you can then calculate the vessel diameter in feet (D).
I also assume that you know the cubic feet per minute of liquid (L) that will be leaving the bottom of the flash vessel. Multiply that by 5 to obtain volume of liquid capacity below the liquid level (i.e., 5 minutes of liquid inventory). Assuming the liquid level will be at about the midpoint of the vessel height H, then :
H, ft = (2) (5 min) (L, ft^3/min) & divide; (A, ft^2)
Now, you have the height and the diameter of the vessel. If that height to diameter ratio is about 3 to 4, you are done. If it is less than 3 to 4, increase the length of the vapor section above the liquid inventory. If it is more than 3 to 4, you may have to consider lowering the amount of liquid inventory so as to shorten the vessel or perhaps even swaging the liquid storage section to a larger diameter.
Keep in mind that the height to diameter ratio is not set in stone ... it is just a rule-of-thumb that a ratio of 3-4 provides the best dimensions from the viewpoint of the cost of the vessel.
Posted 08 September 2005 - 10:20 PM
Posted 07 July 2007 - 02:48 PM
Posted 10 September 2009 - 02:16 PM
Diameter, existing: X1
Diameter, new: X2
Flow, existing: Y1
Flow, new: Y2
If I want to quickly size a drum for an increased flowrate, could I just take the ratio of the flow rates and multiply that number by the existing diameter to get a new diameter? So X2=Y2/Y1*X1
OR
Do I take the square root of the ratio and multiply it by the existing drum diameter. So X2=sqrt(Y2/Y1)*X1
Which one would you pick and why?
Posted 11 September 2009 - 08:05 AM
Since the conditions don't change, the max. allowable velocity doesn't change. The gas velocity in a vertical separator changes with the diameter squared and linearly with volumetric flow rate:
v = Y / A
where A = pi/4 * X2
so X = sqrt[ Y / (v *pi/4) ]
Posted 11 September 2009 - 12:44 PM
Considering the following, for the same service and separation conditions:
Diameter, new: X2
Flow, existing: Y1
Flow, new: Y2
OR
Seriously, the very fact that you are asking this question is a little worrying. By 2nd grade of secondary school I could have told you the answer.
Anyway more to the point, if your flow increases by 20% you're not going to purchase a drum 10% bigger diameter, whats the point?
You would look at ways of increasing the capacity of the current drum, i.e. installation of demisting pad or vane pack, or even looking at the service the drum is in. For compressor suction drums you have to be very strict about liquid entrainment but in other services, say for the sake of argument a flash drum is used to give a liquid + vapour feed to a column a little liquid entrainment would not be ideal, but probably acceptable.
#10
Posted 22 August 2011 - 07:12 PM
I get a very low value of flash drum diameter and height (0.2' X 0.2') for my feed of 2.29 l/min. Please see the excel attachment for my calculations. Can someone please check?
Any advice or criticism is welcome.
Thanks a ton!
Posted 25 August 2011 - 10:00 AM
Diameter of vertical drum =2.8"
Height=2.6' for a liquid inventory time of 1.5 min.
The application is for a small R&D pilot project so the numbers are not commonly seen in industrial applications.
Posted 25 February 2012 - 01:12 AM
#13
Posted 25 February 2012 - 04:29 AM
For the density of the vapor and the liquid you need to consider the mixtures of the components for each phase, In other words, use the mixing rules.
I 've attached a link to support your design :
http://www.chemsof.c...l_Separator.xls
Many more using the search button and liquid gas separator.
Hope this helps
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Lng Boil Off Gas Compressor Suction DrumStarted by Guest_Lyne_* , 04 Jun 2025 |
