A locally applied rule of thump suggests valve closing in 5*d s, d=pipe diameter in inches (e.g. for d=10", valve to close in 50 s). This rough preliminary indication is for pipelines within a plant or refinery, needing more detailed examination in "suspected" cases. But what about long distribution pipelines?
Suppose closing a valve at main line, 60 km far from pump discharge; pressure wave velocity (celerity) is estimated at 1200 m/s. Time for pressure wave to travel to the pump and return is 60*2/1.2=100 s. Any closing time shorter than 100 s has same result as a sudden closure. To "smooth" surge, valve closing time should be "preferably several times 100 s" (*). But most probably the valve should not close too late ("after the fiesta"), so a compromise has to be made between closing time and surge pressure through the aid of suitable software. The latter can also help in specifying required protection against developed overpressure...
(there are intermediate posts)
....As far as betting on rule of thumb being found as a practice of some imaginary reputable engineering company, the forum does not encourage gambling. Constantly mentioning local practices and local rules of thumb also indicate half-baked knowledge and the propensity to bluff.
And as you mentioned "nobody has the right to doubt" cannot be accepted. Anyone has the right to question and ask for justification and if the person is honest he or she will accept his ignorance or lack of knowledge and say so.
Since valve closure time has a major impact on the surge analysis let us get the fact right in terms of practices followed by internationally recognized companies instead of saying local rules of thumb. Here is what Shell standards have to say regarding valve closure time.......
- Recommended time of valve closure was not of interest in the specific case. Surge protection would require time longer than what any mentioned practice suggested, if additional antisurge means were not installed. This is indicated in the first post.
- Nevertheless a found recommendation by Mobil suggests an operator actuating speed of 12 in /min for motor operated valves, that is 1 in / 5 sec. This is judged to comply with first post. 1" valve shall close in 5 sec, 2" valve in 10 sec, etc.
- The statement "nobody has the right to doubt" attributed to kkala is false. The opposite is true, as posts No 13 and 15 by kkala say.
Edited by kkala, 16 January 2012 - 06:21 PM.
